Is there a way to limit the SQL DataGrid to a single query? Also, is it possible to auto populate the table so it doesn't even appear like the user has the option to access the database besides the data I want to display?
You can do the following either from the Graphic Editor or from a Client Script.
1. Override the following custom properties defined in the SQLDataGridUserCrtl and set them to True. This will help hiding the controls on the UI.
ComboBoxPanelHide_dg = True
ButtonPanelHide_dg = True
2. Override the following custom properties to overwrite the connection properties. Some of them may not apply depending on the Authentication mode.
Authentication_dg
ConfiguredServer_dg
ConfiguredDatabase_dg
ConfiguredDomain_dg
ConfiguredUser_dg
ConfiguredPassword_dg
3. Overwrite the following custom properties to specify the SQL command and retrieve the data.
SQLQuery_dg
CmdRetrieve_dg
4. Specify the following customer properties to auto refresh data.
AutoRefresh_dg
AutoRefreshDuration_dg
Alternative: There are also corresponding properties on the control that can be set from a script.
