OMI 2023 MyViewApp.Security.LoggedInAccessLevel
On an OMI 2023 with no patch, I am referencing a custom property to MyViewApp.Security.LoggedInAccessLevel. Using the standard login popup; I manage to login , but all custom references to this tag show empty until I call the graphic again (show graphic), witch I use to define Enable Disable actions on a button/field. I have a dual screen screen profile. I have the same issue on the log off action. Any of you have heard about this one?
  • Hi Denis - I have not seen this but it sounds like there is some binding issue at play.  Would you mind creating a tech support issue for it, please. If this is a bug, we need to pout it through the channel to get it looked at and resolved.
    Thanks
     - Ernst
