Is it possible to schedule an automatic troubleshooting scan to run every day in the AVEVA Common Services Portal? If so, can an export of the troubleshooting scan data be saved to a predefined location?
This would be very useful as we could then parse the data and check the status of each indicator programmatically! I want to monitor the status of each indicator from System Platform. If any of the statuses from the indicators in the Common Services Portal equals 1 - I want to raise an alarm in SP. Maybe FileReadFields(), FileReadMessage(), or System.IO.StreamReader could be used from SP for this purpose. Is there any built-in functionality in the AVEVA Common Services Portal or AVEVA System Platform that would allow for this?
I have not found anything I could use for this purpose in the Common Services Portal 8.0.2, maybe this is different in the newer 8.1.0 version?
