Is there a native way to historize SystemPlatform tags to AVEVA PI? If yes, where to set up?
We want to connect a SystemPlatform natvely to AVEVA PI. Is there an easy to set up?
I have used the Replication Server in the Historian configurator. It replicates to Historian, Insight, DataService and PI. The plantmodel that you have created in SystemPlatform will then also be replicated to PI AF.
I can also add that it is possible to backfill data. Once you set up replication it will only send data from Historian to PI from the time that replication starts running. But there is a tool in the Historian\x64 folder called aahBackfillUI where you can select the timeframe and for which replication you would like to backfill.
