Redundant Network Issues
Good day,
I trust you are well.
I have deployment issues when deploying my platform, deployment gets stuck at a point with no error on the logs. When I disable my redundant network connection it deploys. Can you please assist
Already done the DNS names in the host file and the names resolve correctly.
also set the NIC binding and done the Change Network Account.
Tried to re-install windows and created a new platform but still have the same issue.
Is there a known HF to resolve redundancy issues on a 2014 R2 SP1 system
OS: Windows 10 Pro Version 1909
Thanks.
  • Any messages in the Event Viewer?
    When you say you "set the NIC binding", what exactly did you do?
    If you had deployed before, and there was any issue with an undeploy, it may have left some things behind that need cleaned up.  This is a bit difficult to do by just messages like this.  I would suggest calling in to your local support provider and working to get it deployed.
