Comms on Engine attribute
Hello Team,
I trust you are well.
we are having an issue with engine attribute, as they are losing connection to the OPC.
Undeploying and deploying the engine does not fix the problem. As on the view object the data on the attribute is correct but the quality is bad, as it is not connected to the opc topic.
The only way is to undeloy and change the input source of the attribute and then change it back to the original (once the input source for the attribute has changed)
The version that we are running is V23.0.004.
The cause is unknown.
The above are the warning on the logs.
