How to install MS SQL Server 2022 for System Platform 2023 R2 SP1
I am looking for a step-by-step guide to install MS SQL Server 2022 for a GR node and a Historian Server node in System Platform 2023 R2 SP1. I found tech notes up to MS SQL Server 2019 (like TN 10569) but no mention to SQL Server 2022. Can anyone tell me where to find that?
  • Good day Ismael.
    I believe you may use the document for SQL Server 2019, there is performance improvements, Security (encryption), Azure additional features, intelligence across all data added to SQL Server 2022
    The installation is almost the same, you have to deselect what you do not need when you are installing.
    I have installed it on System platform 2023 R2 SP1 GR node and Historian Node. Please install the same version of SQL Server across your nodes to avoid compatibility issues and security mismatch.
  • Hello Jimmy.
    Besides those new features that you mentioned, I've found another difference in the installation steps between SQL Server 2019 and SQL Server 2022 that's not covered by the document for SQL Server 2019 (TN 10569). Specifically, in the Feature Selection step, SQL Server 2022 does not show the items "Client Tools Connectivity" and "Client Tools Backwards Compatibility" which are requested by TN 10569.
    In SQL Server 2022 that implies some additional manual installation steps after the installation of MS SQL Server, which involves downloading and installing these features from Microsoft site:
    - MS Visual C++ Redistributable for VS 2022 (required for MS OLE DB Driver for SQL Server)
    - MS OLE DB Driver for SQL Server
    - MS ODBC Driver for SQL Server
    That's why I am looking for any AVEVA documentation which confirms if those steps or any other step are needed for SQL Server 2022 in a GR or Historian node.
    Have you found that difference in your SQL Server 2022 installer? How did you resolve it?
  • Hi Ismael,
    my installation was an upgrade from SQL Server 2019 to 2022, the installation process was quite fast and easy, it starts by downloading the install files and install them in one dialog,
    Those requites were already installed by System platform 2023 R2 on my machine, I did not have to install them before.
    the SQL Server install did not request the installation of those components, and please note that my dev machine also have VS 2019 Community installed.
    all i Had to do after the upgrade was to setup my 2020 SQL instance as the primary SQL instance.
  • Hi Jimmy, thanks for your reply. Unfortunately my case is different from yours, so I am still looking for an answer to confirm whether those components are required or not by the GR or Historian Server.
    Currently, we are going back to MS SQL Server 2019 for this installation, but I will appreciate any tip anyone can give me about this question.
  • Hi,
    I've got the same Problem. So I asked the Aveva Support. Here is the answer from Level 2 Support translated by google translator:
     The development department (R&D) has confirmed that Microsoft SQL Server Standard 2022 is fully compatible with System Platform 2023 R2 SP1.
    • The "Client Tools Connectivity" and "Client Tools Backward Compatibility" components are no longer included in SQL Server 2022, but are not required for operation with AVEVA.
    • Tools such as SSMS, SQLCMD, and other utilities can be installed separately from Microsoft if required. However, they are not required for normal operation of the Wonderware GR node unless specific database tasks are planned.
    • It is important that a compatible version of SQL Server is installed on the Galaxy Repository (GR) node. The GR node automatically limits the SQL Server memory usage to 65% of the total RAM. TCP/IP should also be enabled on the SQL Server. The SQL Management Tools are optional and are primarily required for manual database work.
