Good day
Please can you advise if the AVEVA Edge can store and recall data on flat files similar to that of the InTouch,
If so, what are the limitations in regard to:
- Number of tags
- Retrieval rate
- Disk size
Thanks
Good day
Thanks
AVEVA Edge has similar to InTouch "LGH" files, in Edge they are called "HST" and configured from the "Trend Logger" configuration. In the trend logger, you have several formats,
The Trend Logger worksheets can have up to 1000 tags per work sheet, and a project can have up to 999 different trend worksheets.
Rate will depend on hardware.
Scott
Hi Scott
Thank you very much for your response and input. I appreciate.
