OFS and a generic Modbus, Citect SCADA
I need an advice regarding the best way to approach the following issue:
I need to get data from some generic Modbus devices, display data in Citect SCADA and also make data available through an OPC server to other OPC UA clients.
My first plan was to use OFS to collect data from the Modbus devices and connect Citect SCADA to OFS as a client. Also the other applications would connect to the same OFS server.
This looks not feasable because, as I've understood, OFS can connect only to few families of Schneider devices.
Is my understanding correct?
What would be the best way to do this?
Thank you,
Arian
