Citect process starts and stops frequently according to the syslog
Running Citect 7.4 Service Pack 2 and looking to upgrade to Citect 2018 R2.
Noticed something in the syslogs indicating that the Citect Process Starts and Stops frequently , within milliseconds and not sure why that is happening.
The application doesn't seem to actually stop,  the runtime does not shutdown.
Anyone encountered this before?
_______________________________________________________________________________________________________________________________________
2020-10-20 07:53:22.374 +09:30 *** Citect process is starting up ***
2020-10-20 07:53:22.378 +09:30 Data Execution Prevention (DEP), has been enabled successfully
2020-10-20 07:53:22.378 +09:30 *** Citect process stopped ***
2020-10-20 07:53:22.379 +09:30 *************************************
2020-10-20 12:59:37.275 +09:30 Invalid CPU Affinity parameter passed. Requested affinity bit mask: 0x0. System affinity bit mask: 0xff. The process will be allowed to run on all CPUs.
2020-10-20 12:59:37.276 +09:30 *************************************
2020-10-20 12:59:37.276 +09:30 *** Citect process is starting up ***
2020-10-20 12:59:37.280 +09:30 Data Execution Prevention (DEP), has been enabled successfully
2020-10-20 12:59:37.280 +09:30 *** Citect process stopped ***
2020-10-20 12:59:37.280 +09:30 *************************************
2020-10-20 13:00:06.213 +09:30 Invalid CPU Affinity parameter passed. Requested affinity bit mask: 0x0. System affinity bit mask: 0xff. The process will be allowed to run on all CPUs.
2020-10-20 13:00:06.213 +09:30 *************************************
2020-10-20 13:00:06.214 +09:30 *** Citect process is starting up ***
2020-10-20 13:00:06.217 +09:30 Data Execution Prevention (DEP), has been enabled successfully
2020-10-20 13:00:06.218 +09:30 *** Citect process stopped ***
2020-10-20 13:00:06.218 +09:30 *************************************
2020-10-20 13:03:47.076 +09:30 Invalid CPU Affinity parameter passed. Requested affinity bit mask: 0x0. System affinity bit mask: 0xff. The process will be allowed to run on all CPUs.
2020-10-20 13:03:47.077 +09:30 *************************************
2020-10-20 13:03:47.077 +09:30 *** Citect process is starting up ***
2020-10-20 13:03:47.081 +09:30 Data Execution Prevention (DEP), has been enabled successfully
2020-10-20 13:03:47.081 +09:30 *** Citect process stopped ***
2020-10-20 13:03:47.081 +09:30 *************************************
2020-10-21 06:53:40.781 +09:30 Invalid CPU Affinity parameter passed. Requested affinity bit mask: 0x0. System affinity bit mask: 0xff. The process will be allowed to run on all CPUs.
2020-10-21 06:53:40.781 +09:30 *************************************
2020-10-21 06:53:40.782 +09:30 *** Citect process is starting up ***
2020-10-21 06:53:40.785 +09:30 Data Execution Prevention (DEP), has been enabled successfully
2020-10-21 06:53:40.786 +09:30 *** Citect process stopped ***
2020-10-21 06:53:40.786 +09:30 *************************************
2020-10-21 10:34:57.730 +09:30 Invalid CPU Affinity parameter passed. Requested affinity bit mask: 0x0. System affinity bit mask: 0xff. The process will be allowed to run on all CPUs.
2020-10-21 10:34:57.731 +09:30 *************************************
2020-10-21 10:34:57.731 +09:30 *** Citect process is starting up ***
2020-10-21 10:34:57.734 +09:30 Data Execution Prevention (DEP), has been enabled successfully
2020-10-21 10:34:57.735 +09:30 *** Citect process stopped ***
2020-10-21 10:34:57.735 +09:30 *************************************
2020-10-21 11:12:56.134 +09:30 Invalid CPU Affinity parameter passed. Requested affinity bit mask: 0x0. System affinity bit mask: 0xff. The process will be allowed to run on all CPUs.
2020-10-21 11:12:56.135 +09:30 *************************************
2020-10-21 11:12:56.135 +09:30 *** Citect process is starting up ***
2020-10-21 11:12:56.140 +09:30 Data Execution Prevention (DEP), has been enabled successfully
2020-10-21 11:12:56.140 +09:30 *** Citect process stopped ***
2020-10-21 11:12:56.140 +09:30 *************************************
2020-10-22 11:25:32.317 +09:30 Invalid CPU Affinity parameter passed. Requested affinity bit mask: 0x0. System affinity bit mask: 0xff. The process will be allowed to run on all CPUs.
2020-10-22 11:25:32.318 +09:30 *************************************
2020-10-22 11:25:32.318 +09:30 *** Citect process is starting up ***
2020-10-22 11:25:32.322 +09:30 Data Execution Prevention (DEP), has been enabled successfully
2020-10-22 11:25:32.322 +09:30 *** Citect process stopped ***
2020-10-22 11:25:32.322 +09:30 *************************************
2020-10-22 11:25:57.476 +09:30 Invalid CPU Affinity parameter passed. Requested affinity bit mask: 0x0. System affinity bit mask: 0xff. The process will be allowed to run on all CPUs.
2020-10-22 11:25:57.477 +09:30 *************************************
2020-10-22 11:25:57.477 +09:30 *** Citect process is starting up ***
2020-10-22 11:25:57.481 +09:30 Data Execution Prevention (DEP), has been enabled successfully
2020-10-22 11:25:57.482 +09:30 *** Citect process stopped ***
2020-10-22 11:25:57.482 +09:30 *************************************
2020-10-23 10:23:12.040 +09:30 Invalid CPU Affinity parameter passed. Requested affinity bit mask: 0x0. System affinity bit mask: 0xff. The process will be allowed to run on all CPUs.
2020-10-23 10:23:12.040 +09:30 *************************************
2020-10-23 10:23:12.041 +09:30 *** Citect process is starting up ***
2020-10-23 10:23:12.044 +09:30 Data Execution Prevention (DEP), has been enabled successfully
2020-10-23 10:23:12.044 +09:30 *** Citect process stopped ***
2020-10-23 10:23:12.044 +09:30 *************************************
2020-10-23 10:26:37.691 +09:30 Invalid CPU Affinity parameter passed. Requested affinity bit mask: 0x0. System affinity bit mask: 0xff. The process will be allowed to run on all CPUs.
2020-10-23 10:26:37.692 +09:30 *************************************
2020-10-23 10:26:37.692 +09:30 *** Citect process is starting up ***
2020-10-23 10:26:37.696 +09:30 Data Execution Prevention (DEP), has been enabled successfully
2020-10-23 10:26:37.697 +09:30 *** Citect process stopped ***
2020-10-23 10:26:37.697 +09:30 *************************************
