Although compile-time is a good excuse for leaning back a while I am mostly annoyed by it..
But what affects the compile the most? CPU (Cores/Speed)? Disk-speed?
Or is it just bottlenecked by old code that makes up the compiler?
Hi Anders,
Maybe put this on the ideas portal. I suspect you'll get a few votes...
Plant SCADA | AVEVA Plant SCADA (aha.io)
In short, yes there is plenty of opportunities to modernize it. The best thing you can do is give it high clock speed.
Maybe I should post it there, but if such a crucial part of using and developing in Citect hasn’t been upgraded in all this time, there must be a reason. I can’t be the first one rising this question.
But I thank for clarifying what I suspected, and throwing GHz at it goes hand in hand with it being based on old code.
