Plant SCADA run as a service issue with OFService
Hi All,
I am having an issue with Plant SCADA when I configure it to run as a service [Configurator --> computer setup --> Run as a service], it is not connecting to PLC through OFS and it shows bad communication with PLCs, but when I run plant SCADA runtime without using the run as a service option, everything is working good and the communication with PLCs through OFS is good, I have tried to use the OFService to run OFS as a service and this was not helpful and I am still facing the same issue if I run plant SCADA as a service, Thank you all in advance and will appreciate your help.
