Citect Virtualization
Any successful project with Citect over hyper-V, with soft keys and replicas working? (Citect Scada 8.2 / 2 full servers primary and standby / 2 control clientes - Windows server 2016 datacenter)
  • To be honest, most customers I've spoken to use VMWare. They have high availability architectures, some even with hot standby arrangements. All works well as long as the VM images are not copied or modified in any way to inavalidate the softkey. One thing you need to be aware of is that disaster recovery is not supported by the softkey mechanism, since the machine ID is modified and makes the license invalid. If this is something you require, I would recommend using USB dongle with AnywhereUSB. See tech note here: https://softwaresupportsp.aveva.com/#/okmimarticle/docid/TN10403
  • Citect SCADA has been validated on a number of Windows Client and Server OS versions, as per the AVEVA Software Support Technology Matrix, including a number of virtual platforms including VMWare and Hyper-V.
    https://gcsresource.aveva.com/TechnologyMatrix/Report/Details/5927
    If you make sure that the seleced hypervisor has no impact on the guest Virtual Machine that it hosts then Citect SCADA will not have any issues.
    Note with 2018R2 there is the support for windows server 2019.
